Why won’t my left joy con charge?
I had recently changed my switch shell and everything was working so far and then I connected my left joy con and it will work but it won’t charge, so the only way I can use it is on the switch itself. My right one works fine but my left won’t charge.
Bu iyi bir soru mu?
1 Yorum
I was having an issue with the left joycon not charging and eventually the battery died due to this. I was going to buy a new battery and install it myself. But to make sure that was the problem my plan was to swap the bad battery with the good one in the right joycon. When I opened up the left joycon I noticed the battery cable had come unplugged so I just plugged it back in. It was a little tedious to do since everything is so tiny but once I got it plugged back in it worked fine, no issues.
Just thought I'd let everyone know in case the same happens to someone else
Jacob Seibel tarafından
