Ana içeriğe geç
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
137 Soru Tümünü görüntüle
Blown Speakers on 2006 iMac
Hi. I have an 06 iMac 24” with the T7600 C2D and the 7600 GT. I’m trying to fix the old speakers in it. I know I could buy speakers but even so I’d like to keep the originals. The issue is, when it’s at low volume you can’t really here them. But at medium volume it’s really bad. Also any bass what so ever is absolutely suicidal to listen to. I’ve seen that there are speaker repair glues on eBay but I don’t know which one to get as it seems their are a whole bunch of different kits for different ones. If someone could direct me as to which one I should get I would be very grateful. Thanks.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Your other option to repairing the speaker is to use external powered USB speakers. This will by pass the internal speakers and give you much better sounds than you could ever hope for with the dinky internal speakers. As a plus they will move to your next machine.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
But thats cheating @mayer ;-}
tarafından
@mayer I'd like to have my internal speakers working because I need the desk space. I just wanted to see if I could use some stuff like this so I could fix them. Parts are getting harder to find for these old 06's and I don't want to have to end up getting parts from Germany or end up paying a premium to get them from the North American region. Really what I want to know is if stuff like this would work. https://tinyurl.com/y32fbyar
tarafından
@ashneale23 I only have a couple of small speakers on my desks. The big bass sits on the floor. I do not have a desktop machine in the house without external speakers. Really great because I can crank them up and play Van Halen while doing house work.
BYW if you can't find the parts, i probably have them, let me know.
tarafından
@mayer Well, I suppose I'll see what I can do about finding the stuff to get it done. I'll try another set of speakers for now.
tarafından
Yorum Ekle
I’m not sure I follow your direction here. Are you expecting to make your own sound cones and replace the damaged ones? I think that’s going a bit too far here!
I would just find the speaker assemblies and replace them. Here’s the needed guides to get to the two units:
Here’s the needed parts:
Left Speaker Apple P/N 922-7801
Right Speaker Apple P/N 922-7802
The replacement parts are recycled from other iMac’s.
iMac Intel 24" EMC 2111 Left Speaker Resmi
Kılavuz
iMac Intel 24" EMC 2111 Left Speaker Replacement
Zorluk:
Orta
iMac Intel 24" EMC 2111 Right Speaker Resmi
Kılavuz
iMac Intel 24" EMC 2111 Right Speaker Replacement
Zorluk:
Orta
Puan 1
Yorumlar:
@danj No, I'm just trying to use the speaker repair fluid to fix it. Like this stuff.
tarafından
Save your money ;-}
This is only good on big 6" ~ 50" paper cones when you have a single tear. Even still it won't last ;-{
Small cellophane or paper diaphragms are just not repairable.
tarafından
@ashneale23 - The liquid is just a special glue to hold the tear together. People often mis-use it. Its not something you can use on these small speakers. It also effects the sound! The more you use the stiffer the cone gets so you loose volume and the high notes.
Back in the day I was in a band and had a couple of large speakers which we often pushed to far. We had tried saving our pennies with these glues patching the corrugated rim area which would break down the more we used the worse the speaker got. Finally we got back home and we got a new cones put on. While better it was still not as good as a new speaker.
Where are you located? Maybe we can aim you to local supplier.
tarafından
@danj I'm in Owings, MD. I'm able to have the speakers ordered, but i just wanted to see if I could fix the old ones in case the others broke too.
tarafından
OK, then the California supplier I linked to should work for you.
As these are used make sure you inspect them fully to make sure their diaphragms are in good shape before you put them in.
tarafından
Yorum Ekle
Yanıtını ekle
ashtonneale23 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 39
Her zaman: 39
