headlights don't work but bright lights do work
got a 1999 two door tahoe and the headlights do not work, but the bright lights work fine. i tried new bulbs, new fuses and even got a new control switch. what else can i do? and how?
Bu iyi bir soru mu?
9 Yorum
Have a 96 Chevy Tahoe.. High Beams work Low Beans Don't.. As I was looking this up the low Beans Turned on? I hope they stay working but if they don't turn on again what would be the Problem? A short? A Relay? Tia..
Guillermo Beltran tarafından
Brightlight works but dim bim not working
lunga tshazela tarafından
I have a 96 Oldsmobile Auroa passeger headliht is out hi beams work perfect. HELP
Lemitia tarafından
I have a 97 chevy tahoe, low beam does not work, but high beam does. I went thru the fuse box under the hood and I don't see any fuse labeled LO HDLP. Pls help,
johnqv tarafından
I have a 1996 Toyota Tacoma with 2.4l engine and extended cab 2x2. Left high beam does not work even with brand new relay. Solution? I also tried new headlight. No highbeam.
Hannibal tarafından
4 tane daha yorum göster
