Ana içeriğe geç
This Apple Cinema Display is characterized by the M8149 model number and was first released in July 2000
7 Soru Tümünü görüntüle
Erase mark on screen?
A Sharpie permanent marker touched the screen of one of my Apple Cinema Displays, leaving a mark about an inch long. Does anyone know the best way (any way) to remove such a mark with no (or the least possible) damage to the screen?
Maybe a chemical that will react with (remove) the black mark while not harming the display (or not too much), applied with Q-Tip or something? Magic Eraser? Any ideas?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use a LCD friendly spray to do it. Alcohol works too. For Sharpie, I'd use alcohol first since it usually works. Rubbing the screen would work too, but be careful what you use to do this. Some things damage or scratch the panel.
If this doesn't work, then leave it. You'll do more harm then good.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
+ for the editing..try for the fourth, it's subtle..
tarafından
Anodex is a product that seems to be highly recommended. Anyone have any experience with it?
tarafından
Yorum Ekle
Yanıtını ekle
John Brandt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 786
