Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
196 Soru Tümünü görüntüle
Can you upgrade wifi card
I am wondering if it would be possible to put a more modern apple wifi card, for example from a 2017 iMac. I mainly want to do this for the Bluetooth connectivity, also would it be possible to add an SSD and lastly is 32gb ram possible on this model?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have a 2012 iMac then you already have a newer version of Bluetooth 4.0 (the current iMac’s offer 4.2) that as far as I know is fully compatible with everything being produced today. The newest version is called Bluetooth 5 and it is was just ratified and still very early for products.
While WiFi (802.11n) has been upgraded a few times current version (the current iMac offers 802.11ac) it would require more than the board to gain the higher throughput of the newest standards. MIMO requires more antenna’s than what your system has. The newest standard is WiFi 6 and it was just ratified and just being introduced
If you can’t directly wire your system to a hight speed Ethernet network directly you can still leverage it to connect to an external WiFi bridge which has the higher throughput WiFi (802.11ac)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Ok thank you, I am mostly interested in getting the iMac to work with sidecar and unlock with apple watch which is incompatible with the hardware.
tarafından
Yorum Ekle
Yanıtını ekle
David bellows sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 40
