Ana içeriğe geç
The new LCD won't work?
My Itouch's backlight on the lcd was bad so decided to replace the LCD with a new one. Got one and put it in. Now the new LCD won't work at all. Relooked at all connections and everything is correctly connected. iTunes recognized the iTouch, but I can see nothing even when it is on and charging. did I do something wrong or is it a bad LCD?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thanks guys for your help. The hard reset did the trick. There is a small burned looking place on the logic board. I believe that is why the backlight wont work even after cleaning the conection. Can I find a logic board?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you tried a hard reset? Sometime after LCD repair you will need to hard reset the ipod by holding the power button and home button until the device restarts. Its best to do it while connected to itunes because you'll know the ipod has restarted when it disappears from the devices menu in itunes.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
thank you so much. The hard reset did in fact turn on the iTouch, but as my comment above says, the backlight still does not work. There is a small burned looking spot on the logic board.
tarafından
The logic board will be extremely difficult to find and very expensive if you do. Financially you will be much better off to sell yours as is on eBay and just buy a new one.
tarafından
I just wonder if it is a backlight coil or IC that has burned out....any way you could post s picture?
tarafından
Can't take a pic since it is all back together. I'm not too worried about it since the iTouch works great except the screen has no back light.
tarafından
Yorum Ekle
Try cleaning the LCD socket on the logic board with distilled water and isopropyl alcohol. In my experience, no backlight was solved by carefully cleaning debris and corrosion.
Puan 0
1 Yorum:
Did as you suggested. If you see my comment above, there is a small burned looking spot on the logic board.
tarafından
Yorum Ekle
Hello,, I am having the same problem, LCD wont work , just replaced broken glass - screen -LCD , if you look real hard you can see the display is working just wont light up, the old LCD was doing the same thing, is there something else besides the logic board that controles the LCD ??
Thank `s
Update
Tried the hard restart no good still no lcd ???
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew Gibson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,832
