Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
MacBookPro won't turn on after battery replacement. Late 2013/A1398
After replacing the battery and trackpad per the iFixit tutorials, my Late 2013 15” MacBookPro won’t turn on. No fans, no lights, no nothing. Plugged into a charger, the charger light turns amber, and resetting the SMC while it is plugged in causes the charger light to go briefly from amber to green and back to amber (which makes me think the keyboard is connected correctly).
Any suggestions on what else to check or how to debug this? All connectors removed seem seated correctly and none were damaged during the removal.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had a similar issue after replacing my battery. I was able to fix it by removing the cable that connects the i/o board to the logic board, clean it out, and make sure it is seated correctly and snugly. After that cable was correct it booted right up.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
No &&^&^$^ way . Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Kenneth Adelman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 430
