Ana içeriğe geç
Is replacement battery too thick?
I installed a replacement battery and a replacement screen, and it seems like the battery is too thick. I cannot get the case to close completely and there is a blue tinge on the screen at the upper left corner. I think the battery is pressing against the back of the screen.
I guess the problem might be the screen but it seems more likely that the problem is with the battery.
Or possibly I have done something wrong?
Update (10/26/2019)
I removed all of the old adhesive and used new adhesive strips. All new components are from ifixit.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Move the battery cover closer to the battery. (The black thing covering the battery looks like it is peeling away by the volume buttons.) This will be why you can't close the screen.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Can you post a photo so we can see where the pressure mark is?
If the battery is too far to the left, or too high up, then the screen will get caught as you go to close it, causing pressure marks.
If it looks like the image below then it should close properly, unless the battery is defective, or there is a bend in the phone chassis.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I would add did you fully remove the old tape adhesive. from the battery well.
tarafından
Yorum Ekle
Yanıtını ekle
dwkarl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 289
