TV will turn on load then turn itself off
I've had my sharp tv for a little over a year and it started to turn itself off after a few minutes to a few seconds. Sometimes it will work for a couple hours. I've tried to factory reset and unplugging it. Any ideas?
Bu iyi bir soru mu?
Puan
0
Hi,
What is the model number of the TV?
Has it had an software update recently?
Perhaps check if there is an update available to see if that resolves the problem.
If not a software problem, check the warranty to ensure it has expired and then you may have to remove the back (disconnect the power first) and check if you can spot anything amiss.
jayeff tarafından
