Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
245 Soru Tümünü görüntüle
One of my USB C ports is not working, what’s the repair process?
Hi! So recently my MacBook randomly stopped working properly. One USB port is no longer working. No power or device works on that port. Every other port works perfectly fine. What’s the repair process to fix that si glue port?
Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Comments
Is the mate port working?
Does it seem to be loose?
tarafından
Hi, sorry I'm not sure what is the mate port? It doesn't seem to be loose.
tarafından
@Ayushmaan Ganotra - The mate is the one beside it. Each side has two ports. Lets call them Left and Right and A & B
Left Side: Port A - Port B
Right Side: Port A - Port B
Which one is giving you trouble?
tarafından
Hi yeah the mate port does work. It's on the right side. When looking at the laptop it's the one closer to the trackpad.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First step would be testing power and data lines of the Usb port..a multimeter would do for first ones and an oscilloscope would be needed for data lines, providing you have a good board to compare results with. Other than that you’d need a skilled repairer into component level repairs.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
A simpler way would be a simple USB-C power meter like this one: Satechi USB-C Power Meter
tarafından
Yorum Ekle
OK thats a good sign! So the port connector is likely the problem Vs the driver chip behind it on the logic board its self (both ports would have been effected)
Here’s the needed part: MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
You’ll need to first follow this guide to get the bottom cover off: MacBook Pro 15" Touch Bar Late 2016 Lower Case Replacement Then you’ll need to take the logic board out to gain access to the two screws holding the connector core. While it looks daunting its not too bad! Just carefully disconnect the ribbon cables which are held by the metal covers and the mount screws. Use the MacBook Pro 15" Touch Bar Teardown to help you see when everything is. Once the board is out you can gain access to the screws.
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board Görseli
Ürün
$19.99
MacBook Pro 15" Touch Bar Late 2016 Görseli
Kılavuz
Zorluk:
Orta
MacBook Pro 15" Touch Bar Late 2016 Lower Case Görseli
Kılavuz
Zorluk:
Orta
5 - 10 minutes
Puan 1
1 Yorum:
Hi. This is super helpful! I'll give you an update on the situation once I get the parts.
tarafından
Yorum Ekle
Yanıtını ekle
Ayushmaan Ganotra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,758
