Ana içeriğe geç
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Soru Tümünü görüntüle
White band on screen with pink lines
Hello everyone,
I have an (old) Macbook Pro, and for quite some time now, I have a white band on the screen with some pink lines. The screen also is quite loose, but I don’t know if it’s related to the problem. Sometimes the band goes away, but I would say that on average it is always there.
I have attached the picture for you, for some more context.
I have also an LVDS cable for the replacement, but I don’t know if it’s necessary, because I saw that replacing it is a tough job. I am also waiting for a second display to arrive, but I think the problem is related to the cable.
Do you think I can solve this by replacing the LVDS cable? Or I might better check the one I have, and see if there’s something wrong with the connection on the motherboard?
Thank you so much for helping me.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hook it up to an external monitor to verify if this is a display issue (which it appears to be), or a GPU issue, m then you will have a better idea of how to proceed.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hey @mayer I have just attached a second display.
I don't see any white band over there. So "gladly" :) is a display issue.
Now I have to think about just replacing the cable, or the entire lcd.
What you would do?
tarafından
You have a LCD issue, time to replace the display.
tarafından
Yorum Ekle
It looks like your LCD is damaged you can get this replaced by using the guide below. I hope this helps! Taza
MacBook Pro 15" Unibody Mid 2009 LCD Replacement
Puan 2
Yorum Ekle
Yanıtını ekle
Luca S. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 84
