Ana içeriğe geç
Repair guides and disassembly information for laptops manufactured by ASUS.
2517 Soru Tümünü görüntüle
Asus GL553V blank screen lights on and some times turns on some not.
Hello, I have a laptop here and is showing some wired simptoms and I need some other opinions about this.
The laptop is a Gaming One ASUS GL553V :
  • Sometimes I turn on is working and some times seems to turn on but there is no display just blank.
  • When is turning on all the normal display lights are showing fine like battery charging power light etc.. and after I shot the laptop down the light for battery is off even if is plugged in. I try to power on and blank screen again and showing only the power light.
  • I replaced the battery and still same issue.
  • Tried to replace ram modules same..
  • If I leave it on with blank display the fan is not working and gpu and cpu is getting hot.
Any thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
May be the video card or other things are NOT making proper contacts. Carefully disassemble and then try again. !good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the same problem. It’s a BIOS uncompatibility and you need to update it
Puan 0
Yorum Ekle
Yanıtını ekle
Razvan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 235
