Trying to locate & fix thCamshaft Position Sensor on 2012 Kia Forte Ex
For the life of me I can not locate where the Camshaft position sensors are. I am told there are 2. Can someone please help with a detailed description on where I can find these?
Update (11/09/2019)
Oldturkey03 is wrong
I could not find the camshaft position sensor on my 2012 Kia Forte Ex and there is nothing online. But I found it finally. Here is the camshaft position sensor. And this car only has one. Again this is for a 2012 Kia Forte Ex. You have to remove the plastic piece from the top of the engine and the tube going to the air filter to gain access to the camshaft position sensor. I am pointing to exact part on the engine. You have to remove the plug and then wiggle your way to take off the screw, pull it, and replace with the new one. I used a 10mm socket. I hope this helps someone else cause there is NOTHING online for this exact car….until now
Bu iyi bir soru mu?
3 Yorum
My 2012 kia optima starting and dying. Anybody who can help preciate ya?
krish GABRIEL tarafından
Actually, this car does have two if you look directly behind that one on the opposite side of the motor you'll find the other one and by opposite side of the motor I mean close to the firewall. The one that you're pointing at in the picture is the intake camshaft position sensor the one close to the firewall is going to be the exhaust camshaft sensor. I only know this because I literally just changed this on my daughter's car two days ago. Hope this helps
Tadean tarafından
My obd11 meter is saying it need a camshaft/crankshaft pos sensor b there's a part a and part B the auto parts guy was telling me there is 2 of them for cam n crankshaft is a different one my car will start and won't idle it will sputter n die unless I give it gas can I just replace the one sensor the oxygen sensor since I don't have a whole bunch of money
William GeBron tarafından
