Hello, jalotodelima,
if you have a voltmeter at home, let’s measure, if the power supply is working properly or not, easily measure the voltage between the red and black wire of your fan. It must be 12V (11,9 - 12,1) stable. So power on your console, attach the measure + probe to the red and measure - probe to black. If there is no voltage (12V) or if the voltage is dropping down, it’s an issue of your power supply (from the MB to the FAN).
The second scenario of the issue could be the MB signal to turn on the FAN. To measure the mentioned signal, you must have an oscilloscope (if yes, you certainly know how to measure the signal), if you don’t have an oscilloscope, easily un-solder the yellow (or 3rd cable), then power on your console and if the FAN is still not working and the inputting voltage is 12V (first paragraph), the FAN is fault. In the other way, your FAN will work on 100% performance, because you disconnected the speed control signal input. It’s no problem, but if you want to solve the signal issue, you must analyse, where the signal is creating and where is lost.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
https://youtu.be/QGYIOOF3CGI video that I made to show what's happening.
jalotodelima tarafından
Just to give an explanation at all.. I bought a new one and put it in the actual spot. It started working again.
