motion drive belt came off 10 hp 30" deck mower.
motion drive belt came off my Murray Riding Lawn Mower model 30550X92. Need routing diagram and tips on the best way to re-install.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I can not seem to get your precise number out of my manuals but posted the 30500 series diagram which is identical. Here are the instructions for the belt change. Good Luck.
Bu yanıt yardımcı oldu mu?
I see how the transmission belt is routed and that is a great help, but how the heck do u get to it...?
what is the belt size? belt is too destroyed to get any numbers
rappie1952 you clicked on the blue link in my original answer? That will tell you how to change the belt. If your mower is identical to the one from the OP then your drive belt has Murray part number 037X65MA and apparently is a 1/2x30inch belt
My 10 hp 30” Craftsman is basically the same as the Murray.
I have found the best way to replace the 37 x 65 motion drive belt is this:
Identical to Yard King CE riding mower. I had to reverse the transaxle bolts and slacken off the idler pulley nut but otherwise the procedure worked perfectly. A practical solution, well done.
I have the same problem with my drive belt when I put it in first gear I had no transmission and I found the problem with the belt it came off
Son 24 Saat: 0
Son 7 gün: 33
Son 30 gün: 93
Her zaman: 18,796
1 Yorum
Can you let me know what size belt I need to replace on my Murray 12hp 30 inch
Edith tarafından
