Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Why won't my G5 boot?
I turn the machine on, the little light above the start switch does not go on, there is not single gong signifying boot up and nothing on screen. Can't boot from DVD either. Tried removing memory, resetting all cards an devices, and resetting PRAM with the silver button on the system board. Still no luck.
Any suggestions?
Update
Still not resolved. The machine is a 2.0GHz dual tower model, late 2005. I can remove the inner cover and the red light goes on. Tried resetting both PRAM and SMU but still no luck. Earlier in the week, I was able to reboot it but if I turned it off, it wouldn't go back on again. Tried new power cable and different outlet but same thing.
Sounds like the power supply. Where can I buy one for this model? Are there any disassembly guides on iFixit to help?
Bu iyi bir soru mu?
Puan 6
7 Yorum
What machine is this?
tarafından
Thank you for all the responses. I pulled out all components except memory to see if I would get some noise. Nothing. Probably the logic board.
tarafından
The problem I have with my Mac G5 is when I push start button the computer start normal but not chime,no video and suppose the start button light stay on but it not the light go off. And after while the fans go high speed like crazy. I want to know if someone have idea about the problem I will appreciate.
Thank you, this is my Email:jessandrafy@yahoo.com
tarafından
Having the same problem Rafael
tarafından
Same problem with my Power Mac G5 2GHz Dual: It would power up, but wouldn't boot up, no boot chime, no image on the monitor, no power to keyboard/mouse, and after a minute the fans went crazy.
Nothing I tried helped: Complete disassembly & cleaning (filthy with dust), check/reseat RAM modules, check/reseat graphics card, replace PRAM battery, reset CMU, etc.
So, I removed the "B" drive, where I keep all my music, and connected it to another computer so I could listen to some songs, but it wouldn't recognize it. So, I thought the hard drive was bad.
Then one day for the !&&* of it I pressed the power button on the dead G5 to see what would happen...AND IT BOOTED UP AND WORKED FINE.
I put the "B" drive back in, connected it, and clicked "RESTART", but once again it wouldn't boot up.
On a friend's tip, I disconnected the cables to the "B" drive, and the G5 powered up, booted up, and ran fine!
(Continued)
tarafından
2 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
After searching the internet for days I did finally try what I thought was an unlikely cause to this problem -- I changed out the video card. This solved the problem.
My specific problem was that when I pressed the power button the light was lit (no red diagnostic lights on the logic board) but after a brief spinning sound there was no startup chime and there was silence until the fans started up full blast. I had been using the computer and it suddenly turned itself off and I was never able to restart it until I replaced the video card.
If you want to test to see if this might be your problem -- before you spend money on a video card -- take the video card out of your machine and press the startup button. If you get the normal powering up sounds with normal fan noise it is likely the video card.
I had read this solution in one or more posts to this issue, but I couldn't see how that would work so passed over trying it in favor of other possible causes. I am posting this so others will take note that this is good advice even if it seems unlikely.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
En Yararlı Yanıt
Give me an EMC #. It's located at the bottom of the door. What is your current RAM configuration (this is critical) how much and in what slots? Have you changed the battery? Do you have a volt meter? We may be testing the power supply output later without tearing into anything. You don't want to replace the power supply because you don't have the CPU synchronizing software that is on the Apple Service Disk (ASD) that only authorized service providers have. I've been trying unsuccessfully to get one for two years. Without this the fans run wild when the power supply is replaced. I own this machine and just put a new video card in it today. So I'm familiar with it.
UPDATE
The fan syncing software is on the original system installation disks.
Puan 5
5 Yorum:
If the machine booted earlier in the week the logic board is fine. DID YOU HAPPEN TO NOTICE THE DATE AND TIME?
tarafından
I can now give you the URL for downloading the ASD software. I've learned a lot this last year.
tarafından
Mr Mayer, You seem like a knowledgeable source. I recently just bought a used 2008 mac Dual quad core running mac osx 10.9.5 I've used it for less than a month and today when I went to turn it on I noticed a red light before I pressed the button. Yesterday it worked perfectly fine. And today it won't start. It is completely dead/
tarafından
kizer sosay, it's actually spelled Keyser Söze. This needs to be asked as a new question. Along with your exact machine identification.
tarafından
Hi @mayer -- as you mention date and time and I'm having a similar issue to the OP + fans increasing in intensity, I wanted to ask about the effect of the date and time. My G5 was booting up fine until I updated the date accidentally to a date in the past. The G5 then crashed and stopped working. Now I only get this black screen on booting + fans. No chime etc. Do you know how this can be fixed/reverted? Thank you
tarafından
Yorum Ekle
Try removing the graphics card, and putting it back in. If it is installed incorrectly, or just knocked out of place this might solve the problem.
Puan 3
Yorum Ekle
On my old G5 2Ghz, I had the same problem.
The solution (for me) -> plug a VGA monitor with DVI adapter to the graphic card, and it boot when I plug the cable...
I know this is not a thing to do (to plug or de-plug to/from a graphic card when the mac is on, but that was the only thing to power on/down my mac)
Without a monitor plug (or if a monitor is already plugged) , no way to start the G5
It's like there is no power, start switch does not go on.
To shut it down, I needed to de-plug it after the "Shut Down clic" in the finder (elsewhere the G5 reboot but no shutdown)
That was a really, really strange bug...
Until the day I changeg my graphic card for a 6800 Ultra DLL and since that day the power button works perfectly. (same thing for the shut down, no need to de-plug video cable during the shut down process).
Update
Few more informations, this G5 DP 2 ghz was a PowerMac with the "shut down" symptom.
It works for few months without other problem and one day it shut down randomly.
It can power on few minutes/hours/days and suddenly shut down without any explanation.
I opened it, change the 3.6V, reset PMU, ... and nothing change.
According to the Apple center the problem came from the PSU.
A month later they said that was the mother board...
I opened it again and clean the dust.
Same thing.
Opened it again, and I pulled and press different components on the mother board, and the G5 works very well for months.
One year later I added a second Hard Drive, RAM and a PCI-X board and some days later the problem reappeared... the mac shut down randomly again !!!
One more time in the case to clean up and to pull and press components to make sure there was not a unsoldered piece.
Since that day, this "randomly shut-down problem" disappeared, and that was more 3/4 years ago.
This G5 DP 2 Ghz turns every days, almost 24/24 without problem.
i never changed the PSU, never changed the MotherBoard and nobody in Apple center had never explained why was happen and what the problem was.
And I'm not alone, a lot of people with G5 had this mysterious bug.
Apple always denied the problem and the only words from us was "change PSU, motherboard" said to me an Apple repairer, because this shut-down bug was never clearly identified on the G5...
Sorry for my long post and my poor english ;)
Puan 3
1 Yorum:
Your English is great and your post very helpful I also have the shutdown bug, tested all components I could and reseated RAM and eventually it worked again. But next day shut off after 40 mins. I cancelled out GPU but now am thinking of replacing it. Here's hoping!
But
tarafından
Yorum Ekle
Here is a URL for a take down guide for your computer. Hope it helps. Ralph
http://g5.bhmm.net/
Puan 2
Yorum Ekle
There's a whole host of manuals available for macs, at http://www.eserviceinfo.com/ but for the G5, try this link at http://www.eserviceinfo.com/download.php....
It's a multi-part zip file, but it might help. Very detailed, with pictures. I've currently got a PowerMac G5 1.8 Dual-Processor with 4 GB RAM Maxed out, and I'm having problems with this booting up. I've got a bit of free time over the next week and over xmas so I'll give it a go and strip this down and figure out what's what.
Puan 2
Yorum Ekle
If you've tried the graphics card, memory and any other non-stock peripherals, my guess would be the logic board (as its not receiving power properly enough to boot) or its your power supply. I'd put money on it its your board or power supply.
Puan 1
Yorum Ekle
Had a similar problem with the 1.8 dual processor G5 that I'd just re-built from two basket cases. It powered up the fans but with no chime and no further action. Upon advice I checked the ram modules and got two matching and plugged one into the upper of the two lower slots and one into the lower of the upper two. Turned it on and bingo, fully operational!!
Puan 1
1 Yorum:
Thanks buddy, this fix worked on my 1.8 G5. I had two flashing lights upon start up, but no screen. I changed the battery and re seated all parts. Still no good, so i held down the start button for 10 seconds, no good.
Only when i re seated the RAMs in the positions you suggested did i get full start up with screen view and able to set time and date... Phew !
tarafından
Yorum Ekle
Thanks so much for the above post/s, was having the power light come on my G5 1.8Ghz with 2G of ram but that's as far as it went with no screen appearing at all. Ordered & installed replacement battery, which made no difference. Like the post by P.B above I have just removed some of the RAM (but i left matching 512mb's in the top slot of the top 2 and the bottom of the bottom 2) It has fired up first time and I'm now backing up irreplaceable files i thought may have been lost. The fan is pretty noisy now but even if it only works for the next 2 hours i'm grateful,thanks again !
Puan 0
Yorum Ekle
Yanıtını ekle
getitimped sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 84
Her zaman: 41,947
