Ana içeriğe geç
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Soru Tümünü görüntüle
MAC won't boot USB, deleted O/S - tried everything
Hi all
At the moment my mac is only able to start into recovery mode with disk utility etc.
I tried the option reinstall OS X (el capitan), but I’m given an error when I sign in ‘temporarily unavailable’. This is apparently due to a mismatch in Apple ID which I don’t have.
I have downloaded 5 different images, and put them on USB with transmac, as well as using diskutility itself in recovery mode.
What happens is the mac does not recognize the USB install on boot (hold option), however when I go into disk utility, and open file, I can see the .kpg file in there.
The only time it allowed me to select a boot into USB was with snow leopard, as the image is different (no .kpg, instead folders and setting files). But even then I’m hit by some kind of kernal message.
Basically, I’ve hit a brick wall, I work with MS environment and never have encountered such a basic task impossible to resolve. I have spent a week now trying to sort this, I’ve read and searched and tried every possible solution on google.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
Did you find a fix for this?
tarafından
@wlombeidad - For sure! Its the answer below! I've fixed this issue many a time!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
No, you are not source of the problem! Apple messed you up!
Apple lets its OS installer certificates expire to force people to newer OS’s and/or new hardware! Your system can support upto macOS High Sierra (10.13.x). But even if you did apply the Option-⌘-R keys during the boot-up you will still be out of luck! As Apple messed up by not maintain the certificate keys even on these older images too! If you've got an old macOS install image, it will probably stop working today Here’s the needed OS image which has the new certificate How to upgrade to macOS High Sierra Jump to Step 4 to get the file link.
OK, So now I have the needed file how do I use it? Follow this guide to create a bootable OS installer USB Thumb drive How to create a bootable macOS High Sierra installer drive from a second Mac. Then use it to boot up your system to then install a fresh OS.
References:
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Hi, thank you for your answer. However I already tried with Sierra and High Sierra, it just won't boot.
In the mean time, I asked a friend for their apple ID and was able to proceed with the reinstall OS X. This still doesn't explain why it's been impossible to get an image to boot.
tarafından
@iorange - Yes, I know how could this be! Apple wouldn't mess up!
Trust me! Go to the links get the updated image file and start afresh! I just did two systems for people who had the exact same problem as you! With my updated OS installer I reformatted the drive and installed a fresh OS - Done!
tarafından
How to use an old installer :
Don't trash your system, just go to System Prefenceres and switch back Date and Time manually to the day you downloaded the installer from Apple for example july 13, 2018. Find it out with cmd-i. Turn off your Internet router (WiFi). Now the trick is done and you can install old system version. Doesn't work with newer installers that require internet connection to work (Big Sur <<).
tarafından
@akuaku - You don’t need to do that as the links I posted gets you the updated installer.
tarafından
Hey Dan could you help me out please, I've got the same problem, I am using a windows machine to make the usb drive bootable via TransMac. My early 2008 iMac cannot see the bootable device.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Nico sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 10,432
