Silk epil 7 shaver head
The shaver head of the Silk epil 7 has a net on the top that gets damaged often. The company produces replaceable nets but I believe that if you have at least an extra net (from a previous shaver head that was replaced) it is possible to repair the part of the net that is broken. I would like to know if someone has tips on how it can be done.
I am attaching the photo
of this part.
Bu iyi bir soru mu?
I can only offer a suggestion, the harder you push while shaving, the faster the net will get damaged, if you dont push hard enough, then you dont get a close shave. I recommend aggressive disassembly of the damaged unit to see what you need to do on another unit with a good net to see what would be required to repair one the correct way while waiting to see if somebody has done this before. Good luck.
Duane Donaldson tarafından
