Ana içeriğe geç
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
72 Soru Tümünü görüntüle
Is my motherboard dead?
Hi all,
I would like to ask if anyone had a problem with PS Vita 2000 like I do. The console does not turn on, at all. It is charging (solid orange light) but does not react when I press the power button.
I already checked the most common problems and tried those steps:
  • Replaced battery with a known good one.
  • Pressed PS, R and Power button combination.
  • Tried charging it with different charger and power cord.
  • Looked for signs of water damage (didn’t found any).
  • Checked continuity on fuses around the power section (all working).
  • Placed the MB in another unit with working components (power button, controller boards, and battery).
Can anyone give me some advice on how to troubleshoot this one?
Bu iyi bir soru mu?
Puan 1
2 Yorum
Hi, I'm trying to find the fuses on mine since my backlight is not working. Do you have the schematics? Or a picture highlighting their location?
tarafından
@ed Martinez you posted your request on a 3 year old question that is no longer being viewed. Your chance of getting a valuable answer which hopefully helps you with fixing your system, are greater if you create a new question. Give as much detail as possible and add some pictures of your board. https://www.ifixit.com/Answers/Ask
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I managed to revive it. If anyone in the future will look for the answer, here is it:
Take your hot air station, a lot of flux (higher quality will be better) and reflow those two chips at around 320 - 350 Celsius degrees.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Inglés
! My console is back to life! After three years without using it, when I wanted to turn it on nothing happened. I have spent 4 months trying everything, key combinations, change the battery, the charger and the usb cable, but without any results.
As a last attempt Dismantle the complete motherboard, clean everything with a cloth with Isopropyl Alcohol and a toothbrush, dry it with a hair dryer, mount everything again and when you connect it ... Like new.
Apparently the problem was the rusty motherboard.
Puan 0
Yorum Ekle
Yanıtını ekle
Adam Toda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 16
Son 30 gün: 78
Her zaman: 2,227
