Mac won't turn on in special conditions
I was in an extrenely humid area in Colombia and my Mac refused to start for around 4 days, i tried everything but it just refused to start. The charger seemed to work fine but the screen was not turning up and there were no startup sounds. Only the caps lock qould turn up for a second and die again.
However, when I opened it in the plane and kept it under the fan for 10 min, the Mac started and had all my previous tabs and windows open since the last time I could use it.
Then I used it for 2 days in Salento which is much colder and now ot has the exact same issue with not starting. When I plug my usb phone charger into the mac while the mac is charging and I try to turn it on, my phone lights up a charge for a second and ot dies again.
I brought it outside in the sun now and it started after 10 min.
Any ideas what is wrong and if I should get it checked out oe if it is a standaed mac thing? I have had it for 2 years and never had problems.
Thanks and regards,
Desi
Bu iyi bir soru mu?
Let's check the battery and the charging logic. Install this gem of an app CoconutBattery. Take a snapshot of the apps window and post it here for us to see Adding images to an existing question.
You'll want to take two snaps one with the charger plugged in and a second after waiting a bit so the system is using the battery for a while.
Dan tarafından
