Replace 15 inch MacBook Pro (Retina Mid 2012) screen
Hi
I have been looking around for a broken Macbook to repair and came across a 15” MacBook Pro (Retina, Mid 2012) with a cracked but functional screen. Is it possible to replace the glass only on this model.
I’m trying to find out from the seller exactly what model it is as in A#### but I’m awaiting a reply.
Any help welcomed please.
Bu iyi bir soru mu?
3 Yorum
If you can find the S/N on the bottom cover you can plug it into here EveryMac - Lookup. If you have an external display you can also use it to see the 'About This Mac' which will also show the systems details. The last way is to connect your system to another mac via a Ethernet cable and then use Go > Computer {Shift (⇧) and Command (⌘) and the C keys} to access it remotely (if you have the user account info for the system)
Dan tarafından
Thanks for that Dan but I was specifically after info on replacing the screen glass
Peter Newman tarafından
@pedro147 - @arbaman answered that part.
Dan tarafından
