Ana içeriğe geç
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
44 Soru Tümünü görüntüle
How to stop the low pressure message!
Hi, I’ve been having a problem with my 2003 Yukon XL where I constantly get a low oil pressure warning. I have checked my oil and it’s been full and clean every time. I have had the sensor replaced recently. I was wondering if anyone knows how to just turn the message off or at least make the annoying beeping stop?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kt545,
Since you have replaced the oil pressure sender unit get the engine’s oil pump tested by a mechanic.
If there is insufficient oil pressure in an engine it could damage the engine
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
you would need to disconnect the sensor and program the ecu to ignore both. low oil pressure doesn’t mean dirty and low oil, there’s not enough force pumping it around the car, if the wiring is fine and the sensor there is low pressure, I wouldn’t advise just muting the warning as the engine needs it to lubricate itself and could cause engine failure and an expensive mechanic bill.
Puan 0
Yorum Ekle
Oil pickup o-ring.
Very common
Puan 0
Yorum Ekle
Get a better diagnosis could be a couple things. Ultimately change everything at once unlike me.
Puan 0
Yorum Ekle
Yanıtını ekle
Katie Mcdonough sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 82
Her zaman: 2,108
