Ana içeriğe geç
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 Soru Tümünü görüntüle
Why is my machine leaking small amounts of water from under the machin
At times there is water that comes from the bottom of the machine. It is not a flood. Also on occasion the machine has overflowed but think this is due to load size button being in between two settings.
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi,
What is the full model number of the washing machine?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
See if you can isolate the general location of the water leak below the bottom. I would consider the pump for possible leaks at the inlet or outlet. Typically these rubber hoses are held onto the pump inlet/outlet by hose clamps and could need adjusting/tightening.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks stopped on its own.
tarafından
Yorum Ekle
Yanıtını ekle
usrma sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 136
