Ana içeriğe geç
PS4 doesn't accept discs
My PS4 Slim doesn’t accept any discs I put in it. It doesn’t even try to suck it in and doesn’t read it when I manually put it in. I checked all the ribbon cables in the back, they’re all fine. When I push the eject button, it makes the sound that indicates that there is no disc in the optical drive. Any ideas on what might be the problem? I already tried a lot to make it work. Should I just buy a new optical drive?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
As these drives are not really repairable, you would be better off replacing the Blu-Ray drive rather than reparing it.
you can buy a replacement on eBay or new-egg
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I just had a similar issue on a PS4 Slim, turned out to be dirt jamming up the grooves in the disc roller gears, it was causing the rollers to be sluggish and skip a little but ultimately didn’t have the torque to fully pull the disc in or eject it once forced in, this would also prevent the disc from settling all the way in so that the drive could properly read it. Once I cleaned out the gear connected to the rollers and carefully used a small jewelers flathead screwdriver and a nylon brush to clean the other two gears it works like new. Hope this helps others with this issue.
Puan 0
Yorum Ekle
Yanıtını ekle
Charlie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 307
