Ana içeriğe geç
My headphone jack isn't working
I've used different kinds of headphones and it still doesn't work. I need help!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Same thing happened to mine after it was tossed (by someone else) and hit the headboard of my bed. I can still get audio without headphones, but with headphones-- Nothing.
The headphone jack is soldered to the logic board instead of it being a separate piece like earlier iPod models. And so, in order to replace the head phone jack in the iPod touch, you have to replace the entire logic board.
Try backing up your iPod with iTunes and then restore it to that back-up copy. If it starts working, it maybe a software issue on the iPod touch. If that does not work, you can always try restoring it as if it is a new iPod, but then you would loose all your data and settings on the iPod... But it is still worth a shot.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Check to see if you have a broken tip inside the headphone jack.
Puan 0
Yorum Ekle
Yanıtını ekle
Bradley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 5,571
