Why won't the touch screen work unless plugged into power supply
Touch screen won't work unless plugged into power supply
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Maybe there is a problem with your internal power supply (battery & wiring).
Check if your battery connector is still properly in place. If yes, you maybe have a damaged or old battery.
It could be that your battery reached the end of it’s life, and it’s not able to deliver enough power to get the screen to work.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 94
I’m assuming that the device works on battery normally aside from the touchscreen, right?
Alec M tarafından
