Ana içeriğe geç
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Soru Tümünü görüntüle
Why is my back glass not sticking?
I just recently replaced the back glass for my S8 because the old one was cracked. However, the new glass isn't fully adhering to the frame. After applying pressure, a small gap remains on the long sides between the back glass and the phone. How can I make sure the back glass fully sticks?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
did you cleaned and replaced the adhesive too?
Galaxy S8 Rear Cover Adhesive
Galaxy S8 Rear Cover Adhesive Görseli
Ürün
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Yes, I cleaned off the previous adhesive and then used a new one.
tarafından
Is your battery flat? a expanded battery can push out your glass, also a
bent housing can affect.
tarafından
The battery was flat and the housing was also flat.
tarafından
Yorum Ekle
It could be low quality adhesive. I recommend using 3mm adhesive, not the premade stuff. I also recommend to put a soft rag over the phone and leave about 10 to 15 pounds of weight on top of the phone for about 2 hours. I use 3 five pound weights that were previously used for dumbells. Hope this helps.
Puan 0
Yorum Ekle
Yanıtını ekle
Leonard Vo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 316
