Ana içeriğe geç
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why can't I put in the Propeller on the drone
It like I take off the propellers off because there destroyed. But when I put the new ones it won’t go on please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Propellers you trying to replace are they identical with ones you took out? If they are the same ones and doesn't go easy then you can use little wd40 it will slide in easily.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Missing spacer. The propeller sits on a spacer. The spacer connects to the rotating stem. The propeller attaches via the screw. Check your old propeller for the spacer and sore attached.
Puan 0
Yorum Ekle
Yanıtını ekle
Chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 426
