Why can't I put in the Propeller on the drone
It like I take off the propellers off because there destroyed. But when I put the new ones it won’t go on please help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Propellers you trying to replace are they identical with ones you took out? If they are the same ones and doesn't go easy then you can use little wd40 it will slide in easily.
Bu yanıt yardımcı oldu mu?
Missing spacer. The propeller sits on a spacer. The spacer connects to the rotating stem. The propeller attaches via the screw. Check your old propeller for the spacer and sore attached.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 277
