Ana içeriğe geç
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Soru Tümünü görüntüle
Won't Charge, Won't turn on, Won't display the battery icon
Hey all, so this is my brother’s iPad that we’ve been having trouble with. As a quick backstory, he dropped it a couple of days ago. Since then whenever we’ve plugged it in, the lightning bolt symbol appears and the battery bar turns green, yet the battery keeps trickling down. We’ve already tried a hard reset and confirmed it was not the cable nor the adaptor itself, and in fiddling with it, it has now run out of battery. At first, the battery showed up as that red ‘low battery’ icon (and plugged in it didn’t have the charger icon, so again, it indicated charging). But now that won’t even show up. It’s just a black screen no matter how many buttons we press or how many hard resets we attempt. As of right now, it’s a brick with zero sign of life. What do you think could be wrong?
Thanks for reading :) x
P.S: I cleaned out the charging port as well with some paper, so that’s all dandy too.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Alex C, you probably have a dead battery in your brother’s iPad. What I recommend you do is get a battery replacement form apple or a local third party repair shop. You can do by yourself using this guide: iPad 6 Wi-Fi Battery Replacement, but it is extremely difficult and requires you to disassemble the whole iPad. If you are going to do this yourself, make sure to get the right tools and kits and follow the guide step by step. I would get the Essential Electronics Toolkit to get most of the tools needed.
I hope you can fix that iPad!
-Alex
Essential Electronics Toolkit Görseli
Ürün
$29.95
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Even with the battery being dead wouldn’t the iPad still power up when staying plugged in 24/7, just like a laptop with no battery connected? I’m having the same problem but trying to rule out if it’s the charger port or the battery itself.
tarafından
Yorum Ekle
You probably need to replace the charging port inside of the iPad because it might have been damaged, but if that’s not the case then you need to replace the battery instead.
Puan 1
Yorum Ekle
Yanıtını ekle
Alex C sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 1,786
