Why is it getting so loud?
While it's spinning the cloths there is a loud almost rubbing sound
Bu iyi bir soru mu?
Bu iyi bir soru mu?
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. ... If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 28
