iPhone won't boot and Home button is broken.
So I am Into repairs and I recently bought a second hand Iphone 6 to repair and sell. The repair went well and look good as new. The only problem is now the Phone won't boot. When I Power it on the apple logo shows for 2 seconds and then dissappears. After that the screens backlight stays on but does not boot. Keep in mind the home button have been repaired and won't boot into DFU. I've been told it could be the Charging IC or the display IC but the display is working and the battery seems to be charging well. So that is basically that. What could be the other possibilities? I've tried charging it for hours but still does not boot. I cannot take it for apple support in SA because they are kinda not very umm good at repairs and it's not my phone. Also there won't be any warranty since I do repairs and replaced with non apple original parts. The one Iphone 6 I have Givens out 2.94 volts and the one I repaired is giving out a valued jumping between 3.5-3.9V at the battery connector on motherboard . Maybe that has something to do with the problem? I've tried using new batteries but no different results.
Bu iyi bir soru mu?
3 Yorum
Was the phone working prior to your repair...and what problem were you repairing?
Minho tarafından
Post a clear photo of the front panel connectors. Especially the bottom left screw hole.
Chris Stables tarafından
Hey Mino,
The display was working before the repair. The screen was cracked and some touch not working.
I have replaced the:
Charging flex port
The volume/mute flex
Screen complete LCD
A new iPhone 6 case
Home button original but not paired to motherboard.
I also have a feeling
It might be the U2 Tristar chip because there is no connection to PC.
Marcel De Klerk tarafından
