Ana içeriğe geç
Chrysler debuted the 2008 model year Town & Country went on sale on August 16, 2007 as a 2008 model.
20 Soru Tümünü görüntüle
Gas gauge only reads 1\2 tank when empty. And speedometer doesn't work
I have a 2009 Chrysler Town and country van and the gas gauge only goes to half a tank when empty no low fuel light nothing and the speedometer has stopped working. I have pulled ever fuse under the hood and none where blown. Have try holding in the trip reset while key is off and then turn on key holing in reset button until gas gauge went to empty and have tried letting go when the gauges start the rest process.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
having an issue with both of them may be a fault inside the instrument cluster itself? The speedometer would fail if there’s problems with the speed sensor, faulty ECU or broken gear in the speedometer system itself. fuel gauge would fail because of bad or faulty fuel sending unit or there’s something maybe catching it in the cluster, I would start with opening up the cluster first to see if you can spot a fault for both in there.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Larry Newman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 285
