Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Am I able to take out the throttle control motor relay out of ipdm
I just need to know if I'm able to take out the relay for throttle control motor in the ipdm. . My car goes into limp mode but if I tap on that relay it goes back to normal driving conditions.. i just dont wanna force it out and not be able to put a new one in.. but a new ipdm is out of my budget for the second..any suggestions or ideas would be greatly appreciated
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Hi @danielv661 ,
Do you know why the car is going into limp mode?
What are the OBDII scan codes showing?
You may cause serious damage to the engine if you bypass a feature that is designed to protect the engine and get you home (or at least to a mechanic) in the event of abnormal operation.
tarafından
I'm not wanting to bypass it.. I want to replace it with another one..I just wasnt sure if I could take it out without damaging the ipdm. . If I take it out my rpms wont go past 1000 or so.. but I'm pretty sure the relay is my problem. Or the oem. The code was p1128 I beleive.. open circuit in throttle control. Then while I was checking out the relays the throttle control motor relay clicked then the car was fine...but if I'm driving over bumps or something like that the relays shorts again.. I then have to pull over and tap on the ipdm then it starts back up
tarafından
Also wanna say thank u for the quick response..really appreciate it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @danielv661 ,
Don't know the answer but here's a link to the service manual section for an 06 Altima that deals with the ipdm.
Hopefully it is a start.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Yes, you can remove the relay. Beware. If your relay has 4 blades facing the same direction, you will have trouble locating it! The ipdm number I'm speaking of was in 02 Altima mfg dates between 08/2001-08/2002 only. Hope this helps.
tarafından
Yorum Ekle
Yanıtını ekle
Daniel velasquez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 533
