Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
373 Soru Tümünü görüntüle
Ear speaker/Loud Speaker/Mic Not working
Ear speaker and loudspeaker not working on phone call mic sounds funny too!
Did screen replacement on phone not sure if the phone had the issue before the screen was broken!
I did a force restart and sound starts to work but then cuts out anyone knows what I am supposed to do next?
When you push speakerphone button it will sometimes shut it off
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It’s always important to fully test a device before attempting a repair. If you don’t do this, then you’ll never know if the problem was pre-existing or if it was caused by faulty replacement parts or mistakes in the repair itself. It’s not clear if this is a repair you were asked to do for a customer (or friend/family) or if you are buying/selling used phones. It doesn’t change the problem but it does affect solutions moving forward.
Start by re-installing the original screen to see if the problem is consistent or not. While you’re at it, double check your work by following this guide. Take a close look at all the flexes; you want to see if there are any tears (however small) or damage to the connectors. Also insure that all of the connectors are properly seated because the ear speaker and loudspeaker are on completely different flexes but the connectors are relatively close to each other on the logic board.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Old Screen is shattered beyond being used! Cant test phone must be another issue I could try ear speaker flex but why wouldn't speakerphone work if the ear speaker is broken
tarafından
My customer brought it to best buy they are apple certified said that it needed to be programmed... I programmed the OLED but never heard of an ear speaker needing to be programmed did they lie to my customer
tarafından
Just checked the iFixit Store. Here is what they say:
NOTE
The Earpiece Speaker and Sensor Assembly is paired to the logic board. This assembly contains the flood illuminator, which is part of the Face ID security feature. Replacing this assembly will not restore Face ID functions.
tarafından
Yorum Ekle
Yanıtını ekle
Mark D Schlossman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 3,695
