Broken locking tab of the keyboard ribbon adapter
While replacing the logic board, I accidentally broke the locking tab of the keyboard adapter (beginner’s mistake…). I am wondering if there is any chance the keyboard would still work without the locking tab.
At the moment, the keyboard appears not to work. However, I know that the keyboard cable is not particularly easy to put in (MacBook unibody keyboard ribbon cable won't go in), so I am wondering if I still have a chance to make it work by inserting the cable properly (I have been failing to so so far).
Anyone had a similar experience? Any workaround?
Bu iyi bir soru mu?
The picture helps but I can't tell if you broke the ends of the base off. If you did, then we have no means to snap the clip back on as the other side is gone!
This will need a new connector.
As you had a hard time, you'll likely will want to find someone with the needed skills and tools to replace the connector as its not easy!
Dan tarafından
