MacBook not powering on without cable attached after replacement.
I replacement my MacBook battery after it randomly stated ‘replace now’ about a month ago from what I thought was a perfectly fine condition battery. It wouldn’t work without a charger and coconut battery showed a max capacity of 0%
I followed all the steps and had no hiccups I’m aware of however when I initially turned the MacBook on it loaded up but then switched off as I managed to log in. I kept trying to load it up and had the same issue repeated so I had a press around to check it wasn’t a loose connection or something. After doing so the MacBook turned back on fine however when I check the battery on coconut battery it shows then below.
Can someone give me any tips or hits as to what I’ve done wrong?
Bu iyi bir soru mu?
