remote is not working
my remote is not working, even when i put battery
Bu iyi bir soru mu?
first thing double check the battery has been put in the right way round, honestly so many people put it back wrong. Check the buttons on the circuit board aren’t damaged or falling off and no signs of water damage.
This works with the generation before you car defiantly and may work for yours if it needs reprogramming, fingers crossed it works for you.
1. Switch ignition ON.
2. Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
3. Within 4 seconds switch ignition OFF.
4. Within 4 seconds switch ignition ON.
5. Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
6. Within 4 seconds switch ignition OFF.
7. Within 4 seconds switch ignition ON.
8. Within 4 seconds press the LOCK or UNLOCK button of the first remote transmitter.
9. Within 4 seconds switch ignition OFF.
10. Within 4 seconds switch ignition ON.
11. Within 4 seconds press the LOCK or UNLOCK button on the first remote transmitter.
12. The doors will LOCK and UNLOCK once.
13. Press the LOCK or UNLOCK on all additional remote transmitters to be programmed.
14. The doors will LOCK and UNLOCK for each remote transmitter programmed.
15. Switch ignition OFF.
16. Check operation of all remote transmitters.
Bu yanıt yardımcı oldu mu?
It did not work. I changed the window botton on the driver's door. Since then, the remore stopped working.
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 2,034
