Ana içeriğe geç
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
Red charge light blinking, won't turn on afterwards!
Hello! I have one problem, two systems with this problem. When I plug in my DSi and DSiXL, both exhibit a blinking red charge light. But do not charge. I left them both plugged in all night long, then when disconnecting, if I try to turn them on, I get a brief split second screen wtih a blue light, then they turn off. After this I get no lights of any kind. Neither one has been subject to water damage. I AM however using a charging cable that is plugged into a transformer, as my systems are american, but I live in Germany. Could this be causing the problem? I have another DSixl that seems to be working just fine using the same cable and outlet. No problems at all. Any help you can give me would be greatly appreciated!
Thank you!
Bu iyi bir soru mu?
Puan 0
1 Yorum
what if you can not take out the battery?
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Re-seat the batteries. The blinking red light means it is not charging. The blinking light means that an incorrect amperage/current is present. I have fixed a number of these with that symptom by removing the battery and putting it back in. If this doesn't work try the following on the XL.
On the DSi XL since you have 2 of them. Exchange the batteries between the 2. On the system currently working try charging the battery from the other system. That will tell you if the battery is any good. On the system not currently working try turning it on with the known good battery in it. Also try charging the known good battery in it. That will tell you if there is more problems than just the battery with it. If this doesn't solve your problem try oldturkey's advice.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Be persistent. I removed the battery about 10 times before it started to charge... But it charged
tarafından
Yorum Ekle
rebecca, make sure that your batteries are still good. Check your fuses on the logic board. Fuse location for the DSi is shown here For the DSi XL the F1 fuse is near the power connector and F2 is on the underside of the battery PCB. Here is a good guide to help you with it. Good Luck
Puan 2
1 Yorum:
I just bought it less then a week ago brand new charged fine the first time it was charged
tarafından
Yorum Ekle
look at your charger when the input is (AC110 - 240 v.) you need a transformer/power current changer if it is (AC120 - 220 v.) you dont need any transformer
Puan 0
1 Yorum:
micahzi25, explain this a little better for me. I honestly do not follow you on this one. It is my understanding that the AC adapter is 110-240 volt in and 5.2 V out. Neither one of the ranges you are referring to would require a separate transformer, since the AC adapter is a step down transformer.
tarafından
Yorum Ekle
check this link out for charging IC for the DSi but may be the same component for DSi XL
http://www.google.com/url?sa=t&rct=j&q=n...
Puan 0
Yorum Ekle
Someone help my little sisters DSI isnt turning on or charging and she put it under the tap for some shupid reason! does anyone have any suggestions onn what i can do like take it to a gameshop to get it fixed or is there a way to do it at home? i have tried rice but still no look
Puan 0
Yorum Ekle
##&&% u blind mother &&^&@*
Puan 0
Yorum Ekle
Yanıtını ekle
rebecca sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 125
Her zaman: 51,290
