Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Apple announced the Retina MacBook 2015, model A1534, on March 9, 2015 to launch on April 10. It has a new unibody construction and includes an updated trackpad, keyboard, and Retina display.
158 Soru Tümünü görüntüle
rMacBook 12 Keyboard Stopped Working
Hello,
My Macbook keyboard (except the Power button and the trackpad) suddenly stopped working yesterday and I'm unsure which part is defective. No spills or anything of that sort. It was just on, worked on it and left it for an hour so before realizing the keyboard stopped working after I resumed work.
Right now, I've connected an external keyboard so that works. I've resetted the SMC and PRAM/NVRAM to no avail.
After a couple of days struggling to adapt to an external keyboard and the whole setup with the USB hub .... the keyboard miraculously started working again. What in the !&&* is going on...nope. Started acting up again after I let it go to sleep for hours. Opened it back up and not working. Only trackpad, power and I think command, options buttons are working. So odd.
In the meantime, I’ve replaced both the trackpad and keyboard ribbon cables but to no avail. Does this mean it’s time to replace the actual keyboard itself now?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
i've finally solved the issue!
I ordered 2 in total, one off of eBay and one from Amazon. I saw a lot of reviews on Amazon for these cables in general that they're faulty ..etc
I opened the notebook once more to see if I indeed didn't miss anything, so I unplugged the ribbon cable (let's call it #1) and trying turning the macbook on.
Didn't work so I replugged it and only the power button worked.
So I looked at my other two spare ribbon cables, which I tried before and didn't work at that time, and one of them bothered me because of the length.
I had to bend it a little to fit in the connector. I tried that one, bend it a little and just before putting on all the screws again i turned it on an tested the keyboard.
Worked great. Well, I was relieved. So relieved. Spending $100+, got an A+ grade keyboard (this one has quite a few sticky keys!) and all for a faulty ribbon cable that really cost me $13.00
Gddmn.
tarafından
Yorum Ekle
LCD iPhone Ekran Tamir Kit'leri
Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
Shop Kits
Onarım maliyetlerini düşürün, kaliteyi değil.
Shop Kits
3 Cevap
Filtre ölçütü:
Star up in Safe Mode by holding down the Shift key on start-up. See if the problem persists. If not, install a good “Paid For” anti-virus program like Symantec or NORTON and run it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
Alas, safe mode didn't solve the issue. The Keyboard Viewer does show that the LEFT Shift, Control and Option keys are working. Now I'm going to try the antivirus option. Does it have to be the paid version?
tarafından
I used Avast Antivirus and the scan showed it was clean.
tarafından
Yorum Ekle
Now the trackpad and the select few buttons (except the power) that worked has stopped working.
This really sucks.
I’ve ordered the topcase (without the trackpad) already so i’m really hoping that that’ll fix everything once I able to replace it.
Update:
After disconnecting and reconnecting the trackpad and keyboard ribbon cables, the few keys that did work and the trackpad started working again.
Still going to replace they keyboard/topcase when the part arrives.
Puan 0
Yorum Ekle
Unbelievable. I’ve finally replaced the upper case assembly with keyboard and the keyboard is still the only part that doesn’t work. The power button is the only button that works now. I have the original keyboard ribbon cable along with two other replacements ordered from eBay and Amazon but none of them have worked so far.
What could the issue be then? :(
Puan 0
Yorum Ekle
Yanıtını ekle
Eric C sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 25
