Dryer won't turn off.
The setting dial keeps going around without stopping. I replaced the timer switch already. The dryer heats as normal. The dryer will only shut off if I open the door or unplug it. It goes through all the settings.
Bu iyi bir soru mu?
Puan
0
@astro19 what is your dryers complete model number?
oldturkey03 tarafından
It's a 70 series. #97374210
Astro tarafından
Hi @astro19 ,
Does the dryer start straight away when you plug in the power?
jayeff tarafından
Yes. Also as soon as I shut the door.
Astro tarafından
Hi @astro19 ,
Have you checked that the start switch is OK and not permanently operated?
Disconnect the power and use an Ohmmeter to check if it is OK or short circuit perhaps
jayeff tarafından
