Ana içeriğe geç
Televisions made by the Chinese multinational electronics company, TCL.
TCL Roku tv turns on with logo for a fraction of sec, then black out
Hello, I have Model 55S405 TCL Roku TV. When I turn it on it flashes roku tcl logo for a fraction of sec and then screen blacks out. I unplugged tv for 15 mins and overnight , I tried to reset it by pushing reset button and I tried reset from roku remote using “home button 4 times, up arrow 1 time, rewind 2 times and forward 2 times” but nothing worked.
please let me know if there any other way to fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 22
15 Yorum
Hello sir’
My tcl tv is stuck on startup logo i dont know why can u help me for it in my tv i dont have reset option can u please guide me how can i fix it
tarafından
I also have the same problem please help what do I do
tarafından
Solution, buy a new TV. My 55" TCL Roku has been doing this now everyday… it's worse in the morning, circuits are temperamental when it comes to the extremes. Unfortunately, unplugging it every 5 to 15 minutes gets monotonous after doing it 20 times in a row. My TV is only 5 years old. Perhaps it's time to get a different brand and pay the extra expenses upfront for something that will last.
tarafından
I have unplug the tv and still black It isn't working
tarafından
I have an issue with my tcl roku tv as wee but mine problem is the screen stays white not black when i turn it on the roku tv logo pops up then it just goes white i tried reset uplugging it everything can someone help me please
tarafından
10 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had exactly the same problem. I found a temp fix for it at the moment, but it is not an ideal solution.
Anyways, I believe the problem is caused by 1 or more faulty LEDs in the back. I believe this somehow alters the voltage and it somehow triggers a safety mechanism to turn the LEDS off(since they are working at start). I figured that lowering brightness might lower the voltage on the LEDs and that it would not trigger the safety mechanism. I put it on the darkest settings(I turned on the T.V in a pitch black room to be able to see the settings). I turned it back on and it was working. However, it sometimes still triggers what I assume to be a safety mechanism of some sort every once in a while. I just turn the T.V off and on and it should work. If it does not work, then just unplug and redo it.
I know this is not a good fix, but at least it allowed me to watch a Star trek episode on it.
Bu yanıt yardımcı oldu mu?
Puan 5
8 Yorum:
how did you move the setting to its lowest setting if you cant see anything
tarafından
This was the only thing that worked for me! The screen was VERY dark but not completely gone so I turned off all the lights and I was able to get to settings and put on the darker mode. Thanks so much for posting this!!,
tarafından
This helped my TCL to work again but not always. For a more permanent fix would it be the LED light strips or the power board that I would need to replace??
tarafından
Thanks for this suggestion.
It's the one that worked for me.
From another post/thread,
"..I tried all the restart enable disable unplug wait x seconds and finally factory reset and nothing has fully worked.
I get the flash red/logo screen and it turns dark.
I put a blanket over the 40s305 that I got as a gift maybe 3-4 years ago, and I can see everything under there.
I also get the occasional 20+ seconds proper red logo screen as it's ?loading and I get really happy like it's getting fixed, but nope.."
While snooping around in the settings, I also turned off the LED.
I've no idea what that did or does, but along with your suggestion, my tv is working again so I'm just gonna leave it.
Thank you again.
Happy Sunday!!
tarafından
the Led back light is bad check this video: https://youtu.be/LaV6aQ8LIpw
tarafından
3 tane daha yorum göster
Yorum Ekle
@tapan when this “and then screen blacks out. “ happens, in a darkened room, shine a flashlight at an angle against the screen. Check to see if you can make out shapes, silhouettes etc. TCL has issues with backlight failing. If you can make out silhouettes it is most likely the backlight array that has failed. If not, you will have to remove the back cover and check the power board. Measure the outputs to the main board as well as to the backlight LED’s. Let us know what voltages you get. Post some good pictures with your question so the we can see what you see and follow your troubleshooting to help you out further.
Puan 3
10 Yorum:
I have the same problem. How do you jump out the safety circuit to get to test it. I use to be an electrical engineer
Can you send me a pic so I know?
tarafından
Changing the brightness setting to darker helped fix my issue but not always. For a more permanent fix would it be the LED light strips or the power board that I would need to replace?? What usually makes the LED light strips trip out?
tarafından
@paolodeu application of to high a voltage/amperage when they are already weak or a weak spot on the solder connections etc.
tarafından
SO if this happnes then you are basically screwed forever?
tarafından
@Jair Reategui no, not really. All you would have to do is to replace the LED backlight strips.
tarafından
5 tane daha yorum göster
Yorum Ekle
My model 50S425 that is a bit over 1 year old, started doing the same thing.  Was working fine one minute then shut off a show to put my son to bed, after that the tv would turn on, show the red TCL logo screen then turn back off after about 15 seconds.  Then after 10 seconds or so it would turn back on by itself, spend 15 seconds stuck on the red logo screen and turn back off.  It would stay stuck on this loop until I pulled the plug.  I tried everything I read online.  Unplugging made no difference, 1 hr, overnight, still the same red logo loop.  Every trick to fix it I read online didn't work.
The reset button on the back wouldn't work either.  But I noticed that if I held the reset button down for about 40 seconds it would go to the reset menu.  As soon as I let the button go it would go back to the red logo loop.  I tried to keep the reset button pressed down the entire time while I went through the reset process but it would come to a point where the tv needed to reboot and it would then act like I let go of the button and go back to the red logo loop.   I thought maybe it was a firmware issue and loaded an update on a USB thumbdrive and tried to use that during the reset process.  But the TV would not recognize the thumbdrive so it seemed like the USB port was bad.  So a bad USB port along with a reset button that only responded when held down the entire time led me to believe this was an issue with the hardware, specifically the main board.
The screen looked fine during the red logo loop and also while the reset button was held down so in my opinion that board was fine, the power stayed on the entire time the reset button was pressed so it seemed to me the power board was fine.  I was able to connect to wifi in the reset menu while the button was held down so that board seemed to be working fine too.  So I bought a new main board for like $28, only took about 15 minutes to install it.  There are some videos online to walkthrough the process but it is pretty simple.  Works perfect now.  If you tried all the other fixes suggested and none of them work, before you curb the TV, I would try replacing the main board.  I had an HD antenna with a booster that used the USB port for power and I have a feeling that fried my board but who knows.  At least now the TV works.
Puan 1
2 Yorum:
Ok so look on the left side of the tv with an sharp object then hold the restart mini button for 15 seconds no less then take and wait for your tv to reset only way for it to reboot itself
tarafından
Main board replacement solved the flashing splash screen > turning off issue on my TCL 65”. As another poster mentioned, it's a very simple fix and relatively inexpensive. I personally didn't know which board would solve my issue so I bought all 5 for ~$70 at ShopJimmy. Started with the power board, which wasn't the problem, then main board, and wha-la!…it was working. Replaced all the other boards once I determined it to be a main board issue, since I was in there and had replacements on hand. Tossed the original main board and held on to the others, just in case.
tarafından
Yorum Ekle
I had the same problem with mine. It is the power supply board. I bought the whole repair kit on eBay for $99.
Puan 0
Yorum Ekle
 I had a problem with my TLC flashing when I first turned it on but it wouldn't do anything else. I had to buy a special LED strip tester and then I took the back off and found a bad LED strip when I replaced it it was working but unfortunately I had damaged the flat cable connecting the screen to the electronics in the back and part of the screen did not show the proper image.  ideally if there's a bad strip the screen should light up but maybe the area where the bad strip is does not light up however the TLC Engineers chose not to do that for some strange reason so they shut the whole screen down. I suggest you buy an LED strip tester and find the bad strip.
Puan 0
3 Yorum:
Thank you so much Dale & Happy Holidays!
tarafından
I had to take the back off to expose the LED light strips and then used a purchased strip tester to find the bad strip. I replaced it but damage one of the flat cables connecting the LCD screen. So when I turned TV on it stayed on but I dead strikes in the display.
So be carefull with cables.
tarafından
I'm sorry but why would you want to spend $99 on a board to repair the TV when the TVs cost Maybe 50% more of that? You could replace it TV even a 45 inch for as low as $150 or less.
tarafından
Yorum Ekle
Hi. My TCL Tv logo lights up briefly for a fraction of a sec and goes off. Is was perfect initially after which it become treated reluctant to come on and took several tries to get it to come on. Now it's permanent. Digging into it, there are 4 wires on a connector going into the interiors from the mn board. Wt,Rd,Black,Red. Both the Red,s are common and have 90v on it. The black close to it has 66v & the Wt had only 2.5v on it all are taken WRTgnd. But oddly there is no resistance b/w any of these and the Chassis Gnd itself. I assume the feed must be isolated coming off an isolated winding. So now what is wrong, The tv itself is perfect because the standby lamp goes off, and the political port red light, lights up and it is registered on my mobile Hot Spot. Now pz tell me what should I do? Is it the Led bank? Is it something to do with the power feed? Pz someone enlighten me ASAP
Thank you very much. Prashanth Suvarna.
Puan 0
1 Yorum:
this sure sounds like a typical backlight strip failure. To verify this, in a darkened room, shine a flashlight at an angle against the screen, with your TV on. Check to see if you can make out shapes, silhouettes etc. TCL has issues with backlight failing. Post some good pictures of what and where you are measuring. with your question so we can see what you see and follow your troubleshooting to help you out further. Ultimately, you will need to replace the LED trips.
Adding images to an existing question
tarafından
Yorum Ekle
You have to push the home button five times the up Arrow once rewind twice fast forward twice and then let it sit and it cut off and come back on
Puan 0
Yorum Ekle
Had the same issue, I trashed mine and will never buy another TLC anything.
Puan 0
Yorum Ekle
The power supply is the culprit
I replaced it with one from an TCL/55s421
This power supply looks different but will fit and is much more durable
The triangular shaped power supply are garbage!!
Puan 0
Yorum Ekle
Yanıtını ekle
Tapan Parmar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 53
Son 7 gün: 280
Son 30 gün: 980
Her zaman: 94,937
