disc drive sometimes isn't reconnized by the console
sometimes the disc drive isn't recognized by the console
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The Xbox 360 DVD drive is married to the console. You will need to repair the board or reprogram the replacement drive; the method to do it varies based on the firmware of the console, so there's no clear way to do it I can recommend. You need to do this before going on Xbox Live, since a non-matching drive will result in a console ban and treat it as a modified console.
In most cases, the problem is the fuses blow to protect the rest of the drive; I've seen this before. Get a multimeter and see if the fuses by the connector are good. To do this, put it in continuity mode and see if the meter beeps or says SHRT. If it does, the fuses are not blown and the problem lies in another component on the drive PCB. If it doesn't do this, the fuses are blown. DO NOT jump these fuses; this will result in additional drive damage if the fuses blew due to a board or drive PCB failure.
To remove the drive for repair, refer to this guide: Xbox 360 Optical Drive Replacement
Bu yanıt yardımcı oldu mu?
cleaning the laser will NOT get the drive recognized. That only helps if the drive does not recognize a disk.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 911
2 Yorum
you don't give much information for people to help you...
pollytintop tarafından
solomon, do you think there is any chance that you can give more information to your questions? I find it difficult to try to help you with any of your problems. You habitually do not give enough information and ignore the need for more information when people are trying to HELP YOU.
oldturkey03 tarafından
