Multiple answers : Unable to activate FaceID
So having trouble getting the straight answer on Unable to Activate FaceID after parts swap.
Cracked my back glass and had a bricked X which I could use parts from.
So I swapped the logic board into replacement housing, hooked screen back up and powered on.. Screen was dancing around (I guess digitizer is wonky) and message that FaceID unavailable. So decided to use host phones screen. One answer I read was I needed to use earpiece assembly / cable due to ID branding. So I swapped these.. Hooked screen and powered on. Screen better but still FaceID unavailable.
Now my main question is.. What needs to be swapped from original to new in my situation?Does the front camera assembly (which cable goes under battery) need to be?
I hope using the phone as/is will not brick FaceID..
Thanks in advance,
MacK
Bu iyi bir soru mu?
