Ana içeriğe geç
Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 Soru Tümünü görüntüle
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
I don’t know what I did different, but I got the display to work.
Thank you for the replies
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
Puan 0
Yorum Ekle
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
Puan 0
Yorum Ekle
Yanıtını ekle
sunruh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 51
