Ana içeriğe geç
Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Hi,
What is the model number of the refrigerator?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
The light does not light when the ice maker is on position and cannot change size of cubes, but will dispense water.
tarafından
Is there a different motor that runs the ice maker?
tarafından
@barbararod54488
What is the
tarafından
Yorum Ekle
Yanıtını ekle
Mark T. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 7,440
