Ana içeriğe geç
HP G71, HP tarafından üretilen bir dizüstü bilgisayar serisidir. G71 dizüstü bilgisayarlar, G71-XXX-XX model numarasından tanımlanabilir; son ekler seçeneklere ve satıcıya göre değişiklik gösterir.
Why don't my USB ports work?
I've noticed recently that both of the USB ports on the right side of my G71 are not working correctly. Whenever I plug a device into the top one, I get a "USB device not recognized" message, and plugging something into the other gets nothing at all. The third USB port (on the left side) works perfectly fine.
Bu iyi bir soru mu?
Puan 2
2 Yorum
Try reloading the USB drivers. Cheapest easiest fixes first then dive in to innards.
tarafından
my cd roma worked until I update my window
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I finally opened the computer. The ribbon cable from the USB board to the motherboard was unplugged at the motherboard. I now have all 3 USB ports functioning again!
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I would remove the keyboard and check to see the connector for the USB ports on that side is firmly connected. If it is check the ports carefully for damage or debris. I am including a link the the service manual. Good luck.
h10032.www1.hp.com/ctg/Manual/c01713747.pdf
Puan 3
2 Yorum:
Thanks for the link, I'll be sure to try that.
tarafından
Definitely appreciate the link. Thanks for your help in this.
tarafından
Yorum Ekle
Yanıtını ekle
David Hodson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 3,682
