Ana içeriğe geç
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor
189 Soru Tümünü görüntüle
Soru Kapandı
Super Drive no longer working after ram upgrade
Replaced ram modules in Mac Mini with no problems, and mac starts ok and recognizes new memory configuration
but, now the super drive does not work (i do not know for sure that it worked prior to ram upgrade).
questions is: is there any thing in the upgrade process that could have caused the drive to stop working. have checked the mother board/daughter board connector several times (and other connectors)?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
2 Cevap
Filtre ölçütü:
Try re-installing the old OEM ram back in the unit. If this fixes the problem, then there is reason to suspect the RAM. But its been my experience that it's usually just a bad optical drive that will need replacement. They are known for going bad in several of the early Intel and G4 models as well.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
There is a ribbon cable in the mini that connects the superdrive. It is really easy to dislodge this when changing the ram. I disloged it a few times myself. Just check the back of the board with the super drive and I'm guessing that the cable just popped out of the socket. Just put it back in and secure using the side clips and you should be ok.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 759
