Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2686 Soru Tümünü görüntüle
My phone only works when charging
I have dropped my phone a few times and the screen cracked a little. The thing is that about a week ago i was using my phone and it suddenly started lagging and being really slow, but when i plugged it in it worked perfectly. It still works when not plugged but it lags and slows down a lot. Also some times it turns on and off suddenly. I have had my phone for about 6 months and i really don’t know what’s going on. I have tried from just turning my phone off to reseting the whole thing as it was brand new. I honestly don’t know what else to do. Please Help!!! Also to clarify, the battery is working fine when not plugged in.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
You probably broke more than just the screen when you dropped it. Best thing to do is have the screen repaired and have them look for other issues when the screen is off the phone. Good luck.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
You likely need a new battery. Go into your devices settings app, scroll and find the Battery section. Tap on it and then select Battery Health. It will then tell you what percentage it is at, and if it’s slowing it down to prevent the phone from shutting down. If it’s below 75%, it should almost certainly be replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I’ve had similair symptoms with iPads in the past. Sometimes a calibration of the battery is required after some amount of time.
You could try to plug it in the charger, then hold the home button and the power button together. Hold this untill you see the apple logo when its starting up again.
Just a thought..
Puan 0
Yorum Ekle
Yanıtını ekle
Julia Martinez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 816
