Why does my phone keep turning off and back on by itself?
My phone will be sitting there and then next thing I know its turning off and back on. It's really annoying and I can figure out why this is occurring
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @batmanslover ,
Does it do this when the charger is switched on and connected?
The following suggestions are just trying to see if it is a software or a hardware problem:
Try wiping the cache partition and check if this resolves the problem.
If not try starting the phone in safe mode and check it works OK or not. If it doesn’t happen in safe mode then a downloaded app is the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall until the phone works OK. When it does then the last downloaded app that was uninstalled was the culprit.
If still not try a factory reset and check if this resolves the problem.
Be aware that a factory reset will erase all your data and downloaded apps. It will restore the phone to its’ factory default condition, so if you decide to do this ensure that you backup the phone to a computer or the cloud using the phone’s backup feature before performing the reset
Once the reset has been completed, check if the problem is still there or not.
If the problem is still there, you have a hardware problem. The phone will need to be opened and inspected and tested as to the cause. Is the phone still under warranty by any chance? If so get it fixed under warranty.
If it is OK and you’re satisfied that it is working OK, restore the phone to what it was with the backup that you made earlier, by using the phone’s restore feature.
Once it has been restored to what it was, check that it is still working OK. If it is then the reset has resolved the problem.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 96
